Brief Description: More baffles and blast tube holes
I positioned, drilled and clecoed more baffle gap filling rubber today. The outside corners did not lay the way I wanted them to "duh!" so I made a few more templates and then copied them to the rubber stock. The second time looked/worked good. Getting the governor sealed properly was a bit of a challenge. Here I decided to make one piece that slides over the governor like a wet suit. That worked real well. I also added three 11/16" blast tube holes, one for each of the mags and one for the fuel pump. I need to add one more on the front inlet ramp for the alternator, but will wait to hang the alternator to identify the best position. After breaking my second 1/8" baffle rod while threading it, I am going to plan "B" which is to order 1/8" SS pre threaded rod from Grainger. (They are on back order...most likely because they can't thread them ether.
