TERRY'S WEB SITE
Date:  10-1-2014
Number of Hours:  6.00
Manual Reference:  49.3
Brief Description:  Transition pieces
I finished sanding the upper right transition piece and disassembled all the wheel fairings. I final fit each screw hole for size and depth and sanded the mating surfaces. After reassembling them, I applied a little epoxy/micro-balloon/silica mixture to the low areas and will sand it level tomorrow. I also sanded the nose wheel fairing at both upper and lower joint. Because this is where they are actually bonded, I left some of the seam and added the smoothing compound so it too could be sanded smooth.
Upper transition piece
Gear fairings installed
Nose fairing
Nose fairing
