I sanded the main joint (upper/lower) of the nose wheel fairing...and it is coming along nicely. Once sanded, I added a little more (blue) silica to fill in the voids and pin holes. I did a little more work on the right wheel fairing. I added flox to reduce the size of the joint between the forward and aft transition fairing. After the flox was placed, I spread another layer of silica/micro balloons on top to level it off. More sanding tomorrow.
