Disassembled, sanded and reassembled the right wheel fairing and did the final touch up of epoxy. Tomorrow I should finish sanding the right side. On the left, I disassembled it and added a little structural flox to the edge to close the gap. Need to sand and then do the final epoxy on it. I sanded the nose wheel fairing and added the second coat of fairing compound in just a couple places. I decided not to narrow the 1/16" wheel fairing inboard joint so that water will naturally drain.
