Spent the majority of the day trying to place the baffle around the prop governor. My final solution took some time, but had great results. I ended up cutting the piece in half and adding a doubler to the back. Now I can install the aft baffle section and then attach the forward baffle section to it giving me a very tight fit that can be easily serviced. From there I fit and attached the right forward baffle and match drilled the attach holes. I ended the day by getting the left forward section ready to match drill.
