TERRY'S WEB SITE
Date:  9-8-2014
Number of Hours:  7.00
Manual Reference:  48.12
Brief Description:  Transistion pieces
Getting closer to finishing the transition pieces for the leg fairings. I copied what Deems Davis did on his RV10 by installing the transition pieces with epoxy right on on wheel fairing. Deems said it really helps with maintenance, so it will be worth the extra work. I also added some nut plates to the upper fairing transition piece. It will work better then just sheet metal screws.
Main transistion fairing cuts
Upper fairing install
Main transistion install
