I reinstalled the left wheel fairing to make sure it was level and parallel with the fuselage...looked good. I disassembled the unit and taped the brackets so the flox I was about to add would not stick to them. I then added modeling to the rear so the flox would not go over the sides making it difficult to remove. Once it was all ready, I sprayed it with mold release and put candle wax on the screws. I mixed up the epoxy/flox mixture to a peanut butter consistency and applied it to the brackets in three areas. I double checked for level and parallel. Now it just needs 24 hours to cure. I then started the right fairing getting it to fit and ending the day reinforcing the four holes drilled to fasten it to the wheel bracket. I had a little time left so I tapped the four holes 6/32.
