TERRY'S WEB SITE
Date:  8-25-2014
Number of Hours:  7.00
Manual Reference:  48.1
Brief Description:  Lower gear fairings
Getting ready to work on the lower gear fairings, sot the prop can come off and go back to storage. After cleaning the garage, I built an "I-beam" type saw horse 40" wide by 29.5" tall to set up under the main fuselage wing spar to get the main gear off the ground. Once off the ground (flying) I checked to make sure the fuselage was level front-to-back and side-to-side. While I had the saw out, I made the shims and other jig pieces used in this section.
Remove the prop
Remove the prop
Set saw horse, airplane flying
Level the fuselage
Level the fuselage
