I glassed in the two upper air ramps this morning so they would have time to cure over the weekend. After setting them in epoxy, I added some BID glass to form the radius and then covered them with clean peel. Next step is to sand and add an epoxy/flox mixture to smooth out all the corners removing any joints and then add a little fairing compound giving the air a solid, smooth entry way. I did use small pieces of banding steel drilled with a #40 hole as a backer for the cleco which I will remove then once the fiberglass is set.
