TERRY'S WEB SITE
Date:  8-11-2014
Number of Hours:  8.00
Manual Reference:  47.6
Brief Description:  Lower cowling work
I finished the air inlet ramp construction today and test fit them on the engine. After I get the rest of the cowling fit and hinges installed, I will glass them into their final position. Quite a few builders have had the lower hinges on the cowl fail at the eyelets in a couple hundred hours. The consensus is to remove the two lower hinges and install a solid .063 aluminum plate and use screws with nut plates. It will take a little longer to remove the bottom cowling, but fixing it now is lots better then fixing it later. I did get the cowling aft hinges drilled and clecoed. I still need to drill the four screws at the air inlet as well as set the side hinges.
Air inlet ramps ready to install
Lower hinge removed and solid plate installed
Initial fit upper and lower cowl
