TERRY'S WEB SITE
Date:  8-5-2014
Number of Hours:  8.00
Manual Reference:  47.4
Brief Description:  Prop Installed
As I get ready to start the cowling work, I had to temporally hang the prop today. Sure is a shame I could not just add the alternator belt and leave the prop installed, but it will come off a couple times before I am done. To line it up correctly, I had to hang it at a 45° angle because in order to turn the engine over I would have to remove the preservative oil and pull all the lower spark plugs...not something I wanted to do because I am at least a year away from cranking up the engine. So I managed to hang it at a 45° angle. Not too difficult with the cherry picker. After that, I started the cowling work by joining the two halves. I guess some builders have no problem with this section, but I found it to be confusing at best... I did end the day by getting the two halves to fit together at the forward section. More work on that tomorrow.
Prop Installed
Prop Installed
Finding center
Finding center
Spinner installed
Spinner installed
