Brief Description: Spinner prime and nut plates added
I primed the four aluminum spinner parts this morning and let them cure. Later I added the six nut plates to the front spinner plate and the 14 nut plates to the spinner black plate. I installed the filler plate doubler nut plate with flush rivets after putting the spinner side nut plate on it. So the backplate assembly is now complete. I plan to reassemble it to the propeller and do a final check for clearance.
