The right door panel was removed today and the tape was cleaned off of the door interior. I trimmed the perimeter and the window opening and cut holes/slots for the middle latch mechanism and the door latch. The gas cylinder bracket area was then removed and the brackets temporally installed. Two layers of BID and epoxy were applied leaving a space for the brackets. A layer of clean peel was applied to the surface to remove any excess epoxy.
