TERRY'S WEB SITE
Date:  4-30-2014
Number of Hours:  7.00
Manual Reference:  45.15
Cleaned up the console adhesive and applied some cabosil around the door seal filling in any minor gaps left over from installing the seal ledge. I then made added some micro balloons to the epoxy and smoothed out the aft section of the console. Even though this will be covered by a headliner, I wanted it smooth underneath. While the glass was curing, I cut the holes for the 2" air ducts. The air ducts will be installed later so I will have access to the upper rivets to buck. The Hartzell propeller arrived today.
Door seal work
Door seal work
Propeller arrived
Propeller arrived
2" holes for overhead console air tube
