TERRY'S WEB SITE
Date:  3-6-2014
Number of Hours:  8.00
Manual Reference:  Sec 45-7
Brief Description:  Cabin door hinge shims
I sanded the cabin door where epoxy was added to fill the voids and hung it on the left side. The forward hinge landing was quite a mess from the original manufacturing/build up process and took some time to flatten it out. Once done the hinges went on just fine and the door was hung. I then made some shims to level the doors with the cabin top. Vans instructions indicated shims would have to be made and provided some shim material. As installed they were (RF 060 +.040) (RA .060 + .040) (LF .060) (LA .060). There is no binding and the doors sit square. I will prep and prime the hinges and shims before final assembly.
Hinge shims to level doors with cabin top
Shim work done
Shim work done
Cabin doors shimmed and level
