TERRY'S WEB SITE
Date:  2-28-2014
Number of Hours:  6.00
Manual Reference:  Sec 45-5
Brief Description:  Door skin voids filled
I removed the forward/aft index tabs and finished the rough fit of the right cabin door. With a little time left today, I mixed up some straight epoxy and epoxy/cab-o-sil mix to fill any voids I found between the outer and inner door skin. Some of the voids were about 1/8 inch wide...so I used straight epoxy and a 23 gage needle to fill them. There were two other voids that were wide enough to fill with a 1/16 inch surgical hose attached to the syringe using the epoxy/cab-o-sil mix. The will cure over the week end. My plan is to get them sanded and start on the hinges on Monday.
23 gage needle from Grainger
Voids filled
Voids filled
Voids filled
Voids filled
