TERRY'S WEB SITE
Date:  1-29-2014
Number of Hours:  7.00
Manual Reference:  Sec 44-8
Brief Description:  Left wing initial fit up
Received my lower wing fairing yesterday and shaped it for the left wing. Kris and I set the left wing in place and pinned it with two 3/8 bolts. The rear spar was pinned, clamped and drilled multiple times working up to 3/8. A drilled bolt was installed and castle-nut installed to hold it in place. I worked and installed the lower wing fairing. Set the upper fairing in place and drilled the fairing support angles for their nut plates. The wing was removed so I can add nut plates on the holes identified by placing the fairing on the fuel tank. Once done the wing will be reinstalled to test for final fit.
Left rear spar pin and drill
Fuel tank to fuselage bracket install
