TERRY'S WEB SITE
Date:  1-26-2014
Number of Hours:  3.00
Manual Reference:  Sec 20
Brief Description:  Installed Garmin autopilot brackets
Today I removed the Trutrak autopilot servo mount and installed the Garmin mount for the GSA28 in the right wing. The Garmin pinout calls for 1- shielded twisted pair and four #22 AWG wires. Because I already had 7 #22 AWG wires originally installed for the Trutrak... I only reeded to add the single shielded twisted pair. Inserting the wire went well. I inserted an 8' steel brake line into the conduit, routed the twisted pair through the brake line...and then slid the brake line back out...leaving the twisted pair in the conduit. I will change out the 15 pin connector when I wire the rest of the plane.
