TERRY'S WEB SITE
Date:  1-23-2014
Number of Hours:  6.00
Manual Reference:  Sec 44-8
Brief Description:  Finished Right wing initial fit up
Finished the right wing attach, removed it from the fuselage and Kris and I put it back into the wing rack. All the parts need to be scuffed, alumipreped, alodined and prime painted...but I will wait until I finish the left wing so I can do all the parts together. Once the parts are painted, I will install the fairing stiffeners, nut plates and fairing attach angles. Kris helped me prep the left wing to receive the lower two nut plates. The fuselage was turned 180° and strapped to the carrier so I can start work on the left side. I don't know who first designed the fuselage carrier, but by adding a section to carry the tail and wheels, it is very sturdy as well as mobile. So thanks...good design.
Right wing initial fit up done
Left wing nut plates
Left wing upper fairing support brackets
