TERRY'S WEB SITE
Date:  1-22-2014
Number of Hours:  7.00
Manual Reference:  Sec 44-10
Brief Description:  Wing fairing support angles attach
The fuselage/fairing support angles were clecoed to the fuselage and drilled. I then removed and drilled them for nut plates and reinstalled. I removed the wing to install eight nut plates in the leading edge and upper tank surface to secure the upper wing inspection plate. I then drilled and dimpled all the support brackets that will be riveted on after they are primed. I also located where the wiring will leave the wing and enter the fuselage. I pinned the wing to the fuselage again and installed all parts. Tomorrow I plan to remove the wing, turn the fuselage around and attach the left wing.
Right tank vent
Right tank vent
Right wing upper fairing
Right wing fuel vent tube
