TERRY'S WEB SITE
Date:  1-21-2014
Number of Hours:  8.00
Manual Reference:  Sec 44-4
Brief Description:  Right wing initial fit
After pinning the wings with 3/8 bolts, I aligned, clamped and drilled the rear wing spar for a 3/8 bolt. I drilled and dimpled the lower wing fairing and clecoed it in place. This allowed me to locate the holes for the remaining 8 nut plates that will be installed in the wing. I trimmed the front. Fairing to match the contour of the fuselage and installed the upper section. I finished bending the fuel line and fuel vent line and installed both. The fuel line can be installed after the wing is bolted up, but must be installed before the lower wing fairing is installed.
Right Wing, rear spar attach
Right wing, lower fairing attach
