TERRY'S WEB SITE
Date:  1-20-2014
Number of Hours:  8.00
Manual Reference:  Sec 44-3
Brief Description:  Right wing fit up
Today's goal was to start the fit up of the right wing. I first bent the fuel line to fit, and found the it can be installed after the wing is attached...which is a nice plus. I pinned the wing per instructions using three 3/8 bolts. I did have to place a support on the outboard wing edge to help carry the weight so the fuselage did not roll off the cart. After inserting the three pins. I used an aluminum roofing nail (which is same OD as a #30 cleco) to pin the rear spar in place. That will be clamped and drilled for a 3/8 inch bolt tomorrow. Having just a little more time, I test fit the upper and lower skin just to see how it fit. I was very happy with the results.
Right Wing fit up
Right Wing fit up
Right wing fairing space
Right wing joint
Right wing joint
