TERRY'S WEB SITE
Date:  1-10-2014
Number of Hours:  4.00
Manual Reference:  Sec 37-7
Brief Description:  Tunnel fuel line connections & control connections
I made a fuel line connecting the Andair tank selector valve to the inlet side of the boost pump. That completed the fuel section except for the fuel line that will connect to the each wing tank. That will be installed with the wings. I spent the rest of the day working through all the control connections adding pins to the castle nuts, torquing and torque sealing the push tube jam nuts and supporting brackets.
Boost pump fuel line to valve
Boost pump top tunnel view
