TERRY'S WEB SITE
Date:  1-8-2014
Number of Hours:  6.00
Manual Reference:  Sec 37-2
Brief Description:  FT60 transducer & boost pump platform
Finished cleaning up after completing the inventory of the Finish Kit. I then mounted the FT-60 "red cube" fuel transducer. I used (2) AN17A bolts with two washers on each bolt. AN4-16A was too short and the AN4-17A with one washer was a fuzz too long. I formed/installed the 3/8 fuel line from the transducer to the firewall and torqued and sealed both ends. Next I started on a mounting platform for the Andair fuel pump and filter. I made the platform to be easily removable so the fuel filter can be serviced. After fitting up the parts, they were scotch brited , alumipreped and alodined. Tomorrow they will be painted and assembled.
FT60 Fuel Transducer mounted
Andair boost pump platform
Boost platform alodined ready to paint
