Assembled the elevator idler arm and installed it in the tunnel. Then drilled and assembled the control stick bases. Next I installed the control column and attached the sticks. Once attached, the middle push rod was adjusted so that the the control sticks were parallel as measured at the base and top of the stick. A few of the parts will have to come back out because I have not installed my fuel pump or filter. Those parts that will stay put were torqued and marked with torque seal.
