TERRY'S WEB SITE
Date:  9-18-2013
Number of Hours:  8.00
Manual Reference:  Section 32
Brief Description:  Conduit under floor start
I worked on my conduit runs today making all the lightening hole supports and drilling access holes in the side of the L/R rear seat deck. The conduit will be hidden in the wall when complete. Stein had some heavy duty rubber grommets that were perfect for the Vans 5/8" ID conduit? After scuffing and deburring, they are ready for alumiprep, alodine and paint. I also had time to cut all my SoundEX SX-1000 that will be used on the belly under the rear seats and cargo bay. I am very impressed with their product and customer support. I sourced aluminum tape that meets FAR 23.853 from Grainger to use to secure the insulation when needed. I still need to figure out my RG400 antenna coax wire runs before closing in the seat and cargo by deck.
Cutting conduit run holes in floor
Fasteners for spar transition
Initial conduit run
Initial conduit run
