TERRY'S WEB SITE
Date:  9-4-2013
Number of Hours:  8.00
Manual Reference:  Section 31-8
Brief Description:  Skin fit up on upper forward fuselage
With all the upper forward fuselage components alumiprepped and alodined last night, I was able to epoxy prime the parts first thing. After curing, I assembled the parts and installed nut-plates with the goal of getting the skin attached so that it could be match drilled. After the initial fit up, I removed the upper fuselage and match drilled the two angle supports I had to make for the upper front panel. I then added nut-plates and installed with screws to make sure it fit well. It did fit well. I ended the day sticking my instrument decals back on the panel face.
Skin fit up on forward fuselage
Left side fuselage
Left side fuselage
Fuse forward section view from rear
