TERRY'S WEB SITE
Date:  8-30-2013
Number of Hours:  8.00
Manual Reference:  Section 29-22
Brief Description:  Forward floor pans and lower gear installed
Today I blind riveted the L/R forward floor pans. Because I set the gear in place before I riveted, there were two rivets I could not get to with blind rivets, so I used AN470AD4-4 instead. They were actually easy to get to with the rivet gun and bucking bar. When I finished the forward floor, I installed both the L/R lower gear. The bolts were rather difficult to get to, but in the end all bolts were installed, torqued and marked with torque seal. To end the day, I installed the two remaining forward ribs that were left out so the pan could be installed. The rear steps are next.
Forward floor and gear install
Forward floor installed
Lower gear installed
