TERRY'S WEB SITE
Date:  8-14-2013
Number of Hours:  9.00
Manual Reference:  Section 29-12
Brief Description:  Fuselage skin substructure
After match drilling the longerons and bulkheads, I match drilled the firewall brackets with the forward skins. Once all holes were drilled, I removed the skins to gain access to the sub structure. I placed the to front side channels back in place and clecoed them using the holes I just matched drilled. Then I drilled the upper and lower part of the brackets. Now comes the task of disassembly, deburring, scotch bright and prepping for primer.
Left lower firewall bracket
Left upper firewall bracket
Right upper firewall bracket drilled/clecoed
