Today started with reworking the forming tool that I used for the middle skins so that I could form the forward skins. I roll formed both the left and right skins and checked them for fit. After fitting the up, I removed them and started to install the skeleton the skin will attach to. Lots more fitting and drilling. I ended the day with almost all the holes matched or final drilled. Tomorrow I will finish the drilling and remove the skins to expose the upper and lower firewall brackets
