TERRY'S WEB SITE
Date:  8-7-2013
Number of Hours:  8.00
Manual Reference:  Section 28-17
Brief Description:  Seat structure and gear mount fit up
Manufactured the seat floor angles, floor attach strip, floor covers and floor. Also drilled and countersunk e mid seat rail supports. I plan to do a little more before I paint. I spent the rest of the day fitting in the L/R landing gear supports. They have to be temporally installed so the front gear mount support can be fit to the front floor pan and outside floor rib and drilled. I did this twice because the first time I forgot to temporally install the floor pan. After getting all the parts set in place and bolted down, the front support was marked and drilled.
Pilot seat tops. supporting angles and covers
Right side gear mount test fit
Right side gear mount from underneith
