Brief Description: Attaching gear mount and shaping longerons
Today started by placing the front fuselage skin to locate four bolt holes I needed to drill to secure the side of the landing gear mount. Once drilled, i removed the skin, gear mounts and front floor pans so that I could add two nut plates on each to secure the front most leg of the landing gear. Because there still was not enough to paint, I pressed on to Section 29 "FUSE SIDE SKINS". I cut and formed the mid fuse longerons to match the F-1046B template. After that, the angles were drilled and set aside.
