TERRY'S WEB SITE
Date:  7-22-2013
Number of Hours:  7.00
Manual Reference:  Section 28
Brief Description:  Forward fuse sub assembly
Riveted the OUTBD FWD & INBD FWD seat Rail Supports together, as well as added a bunch of nut-plates to the fuselage rib attach angles. Riveted the nut-plates and spacers to the L & R Bulkhead Side Channels. Drilled and installed the trim control column mount and pre-assembeled the L&R Fuselage Bulkhead Sub-Assemblies. Tomorrow, I plan to start the Fuse Bottom Skin.
Rail supports
Rail supports
Rail supports and Bulkhead assemblies
