Started Section 28: FWD FUSE RIBS, BHDS & BOTTOM SKIN this morning. I fabricated a couple attach angles, OUTBD & INBD forward seat supports and the L & R bulkhead side channel. I sent a question to Vans Tech regarding the countersink instruction on 28-2 that calls for countersinking the nut-plate holes in the fuse ribs. I think that has been changes because There are no holes to be found. I should hear back Monday. Next is to alumiprep, alodine and epoxy paint these parts.
