TERRY'S WEB SITE
Date:  7-19-2013
Number of Hours:  5.00
Manual Reference:  Section 36
Brief Description:  Brake lines in tunnel
The RV10 by design does not come with a parking brake and this was one of the components I decided to add. I chose the Matco PVPV-D brake unit. Vans sells the brake and a well designed installation kit. I clecoed it to the firewall so I could run my brake lines through the tunnel. The tunnel is going to get pretty crowded in the near future, and this will be a good time to get these lines installed. The bending went pretty well... I did prep for the work by watching several you tube clips on tube forming. I also had purchased some pretty good tools. That and a little practice....paid off. I plan to remove them before I rivet the rib subassemblies to the firewall...and attach them later as the tunnel starts to fill up. There is enough clearance for insulation behind the lines.
Left Brake line
Left Brake line
Brake lines in tunnel area
Good clearance for the lines.
