TERRY'S WEB SITE
Date:  7-7-2013
Number of Hours:  4.00
Manual Reference:  Off Book
Brief Description:  COMM Antenna Base Mounting
After making the COMM Antenna bases and fitting them up, installed them, drilled holes for the antenna, added nut plates and mounted the antennas to make sure they fit well. I will do a final attach of the plates when I install the bottom fuselage skin...cause one side uses the same holes. The other side I used an angle to fasten it to the rib. All worked just great. I then removed the antenna, boxed them up for storage for about 18 months.
COMM antenna mounting plate
Antenna mounted to plate
Both antennas complete
