Brief Description: NS90 plates, harness connections and ground lug
The NS90 NAV/Position/Strobe lights recommend a ground plate which I manufactured out of .062 aluminum plate. To connect to ground, I added a wire on the harness that will run from the ground plate to the outer most rib on the wing. There I fastened a prong connector that I got from Stein Air. I soldered all the pins/sockets in place for a better connection
