Brief Description: Complete left wing bottom skin install
Finially got the bottom skin installed on the left wing..all went well. Installed the backing plate for the Gretz heated pitot as I went... and located the pitot far enough away from the tie down so I don't have to be concerned. I dimpled and added nutplates to the three access panels and installed the covers on the wings. I still have to figure out what connector to use for the aileron trim servo motor given there is not a lot of room to work with. Right now, I am considering a 9 pin D Sub, or molex. The problem is the wires are 26 AWG (pretty delicate) so what ever I come up with has to work with that. Next is the wing tip fairings.
