TERRY'S WEB SITE
Date:  4-16-2013
Number of Hours:  8.00
Manual Reference:  Section 20
Brief Description:  Left bottom skin and pitot tube
While the tank seal is curing on the conduit of the right wing, I started to do the initial fit up of the left wing bottom skin. I roughed in the pitot tube location the other day and got almost all the wiring completed, but did not put a hole in the skin for the pitot tube mounting bracket. I clecoed the mounting plate to the skin and traced around the opening and using a dremell tool, made a hole. Turned out very nice. From there, I hung the skin and matchdrilled all the holes. When I removed the skin for final prep, I modified the upper surface of the inboard bottom skin and the underside of the outboard skin where the two overlap. Then started to dimple all the components.
Pitot tube fit up
Pitot tube fit up
Pitot tube first rough install
Modification of inboard lap joing
