Saved a little time by painting the inside of the torque tube to bell crank push rods several weeks ago when I had some extra epoxy paint. I drilled and added the end caps and final assembled the torque tube to bell crank pushrods and then painted them. Because the bell crank to aileron push rod is powder coated steel, it required sanding before I primed them inside and out. They will cure overnight and I plan to assemble them tomorrow.
