Completed the right Flap today... and it turned out as flat as the left... Life is good. I gathered up all the required hardware and installed the flap and aileron on the right wing. They work very well. Next week I plan to test the fuel tanks. The wing tanks were completed two weeks ago Monday, so the pro-seal should be well cured. After they are tested/fixed, they will be installed on the wing. Following the tank installation, I plan to work on the wing control components (push tubes). I ordered the Fuselage yesterday.... should take about two months to deliver. I deleted the standard fuel valve for the Andair model and also upgraded the windows to Cee Baileys. It will be interesting to see how they fit.
