Started the final assembly of the Flaps. Final assembly starts by assembling some of the flap components. Once all the sub components are assembled they are clecoed to the flap spar. After all components are added, each component is then riveted in place. I did get both the left and right flap through this process. I then clecoed the inboard and outboard leading edge to the left flap and placed it in the flap fixture I made. The top skin was then added and clecoed to the nose and trailing ribs and spar. I ended the day placing the rivets in everyother hole and covering them with tape. I will start tomorrow by riveting the top skin in place.
