Brief Description: Finished fit up of aileron leading edge and start
Finished the right leading edge of the aileron including the center spar and counterbalance installation. .. and then started on the ailerons trailing edge. Manufactured 32 stiffeners and attached to aileron skin. (that took more time then I thought it would). I did the initial assembly and match drilled all the #40 holes for the stiffeners. They get prepped for paint tomorrow as well as the skin, spar and other pieces.
