TERRY'S WEB SITE
Date:  2-26-2013
Number of Hours:  16.00
Manual Reference:  Section 18
Brief Description:  Sealed 80% of left wing fuel tank
Using proseal does not work well with cameras so photos are limited. Larry and I spent the day prosealing and riveting 5 interal ribs, one outboard rib, the aft side of the inboard rib, J channel and setting vent line. The clecos took about two hours to clean up... and I was glad I covered the work bench before starting. After a few days, I will install the fuel tank float and seal up the rear.
Left wing tank with back removed
