Brief Description: Cleaning, reworking and painting Landing Gear
Sitting in our open hanger played havoc on the fuselage. Well, the landing gear powder coating was just as bad with pinholes everywhere. So, we will remove the gear, remove the powder coat from all the components and will use epoxy paint once everything is cleaned primed and bluing of all non painted surfaces is done.
I tackled the bungee arms today by striping them, cleaning and treating all the former rust areas and bluing the slide tubes, inside and out prior to priming. I still had time available so I stripped one of the gear legs in preperation for tomorrows shop time.
