Left gear is almost complete. Waiting for the rubber coating on the wheel halves to cure. Discovered the innertube valve stem is quite long. It interferes with the axle nut. We will have to fabricate a rubber washer to sit between the inner wheel and the innertube. We need to shorten its extension by 1/2".
