Brief Description: Better brake set up. Finished gear
The right gear leg is complete. As shown in the previous entry, the new solid spacer gives brake /wheel assembly a stronger solid mating. No more fear of snapping bolts on landing and the fear of loosing a wheel from possible hard landings.
Now I have to ensure the tires are seated properly on the rim so I can re-seat the innertubes, align the valve stem and reinflate the tires to the proper air pressure. I have to say that I would prefere tubeless tires, but this is what came with the kit. We might change over after we fly off our first 40 hrs.
First photo shows rubber coating to prevent innertube from slipping upon touchdown.
Rubber coating on iside of rim to keep innertube from slipping
