RR3 Web Site
Date:  9-13-2019
Brief Description:  Shaping wing tip
Well, shaping started out ok but became difficult real quick. I falied to realize when I epoxied them in place that the tolerances between the framework and foam was going to be tight. After making a mess with the grooving, the epoxy was too much. While shaping I ran into high spts of epoxy. So, they will have to be ground out and back filled.
Cutting excess off
Cutting excess off
Cutting. Ran into hinge will have to sand out.
Epoxy is in the way. Can't get flat contour.
