Good thing I took a lot of notes on measurements for the wing tips. It did not take long at all to lay out and double check everything. I am sure there will be some minor mistakes once we get started on them but, I will cut everything longer and trim as needed once we start. My biggest concern will be bending the compound curve of the leading edge transition to the outer bend of the tip. Will have to take our time on that part of the job. The trailing edge will take some careful bending and fitting as well but that will be the last leg of the task. Anyway, the layout is complete.
