RR3 Web Site
Date:  1-1-2019
Number of Hours:  1.25
Brief Description:  Aileron Cont.
Glue has dried and work on the leading edges begins again. Slots are cut and regluing the foam back to the side of the ribs will take a day to cure and finsh work can begin. The slots are positioned about 1/8th inch from the ribs, so, in order to keep the gaps just the right size, I have to fill those areas in before I can finish the slots and begin shaping.
Repaired sections
Repaired sections
Center slot cut
Center slot cut
End slots need final cutting once the glue dries..
